Hi All, I have searched e-bay Craig's list and several other sites and I can not find speed parte for a 1951 Commander V8, or any other studebaker. I know a man who has a 2 carb manifold and he wants $1000 for it. It is the only speed part I have found. It looks so tall that I wonder if the hood would close? Air cleaner ? What is it worth? Bill-W
Are there any speed parts around?
The only 2 carb manifold I've seen for sale lately is one for a boat. The angle of the carb base is too far off for automobile use. Most of the speed stuff is cams, 4 bbl intakes and higher compression.
The higher compression can be obtained in several ways, but I would not recommend that any more. The gas sucks and won't really support the very high compression too well.
Cams can be bought through some of the vendors. Usually the basic Avanti cam is a good choice. Not radical, but enough to wake up a Stude V8.
Intakes can be found for a single 4 bbl fairly easily.
All depends on what you want to do with it.
There are some die-hards still racing Studebakers and taking them above 200 mph. So it can be done if you have the budget.
Now then, if you just want to go fast, you could do a turbo or two. Those are not too tough to fabricate and you can get some very streetable horsepower.sals54
For the 232 there were Offy 4 bbl manifolds available. Some say they were not that good , but they were good on the 232, it also shaves several POUNDS. If that was mine and it had to stay a 232, I'd use 259 heads and shave them looking for 9 to 1 ratio and add the 259 exhaust manifolds and duel exhaust for sure with an R1 cam. It was done quite a bit back in the day, and better cams/ tech. is out there today. Get a newer distributor and tweak the timing until it is perfectly tuned.
Originally posted by Bill-W View PostHi All, I have searched e-bay Craig's list and several other sites and I can not find speed parte for a 1951 Commander V8, or any other studebaker. I know a man who has a 2 carb manifold and he wants $1000 for it. It is the only speed part I have found. It looks so tall that I wonder if the hood would close? Air cleaner ? What is it worth? Bill-W
Look here :
Bill H
Daytona Beach
SDC member since 1970
Owner of The Skeeter Hawk .
The speed parts are out there, but for a Studebaker you won't find many parts at Summit or Jegs. A Studebaker V-8 can be very peppy with the right combination."In the heart of Arkansas."
I have a Stu-V with the larger ports and front-facing 2-bbl carbs. It has two of the the correct early 2-bbl carbs (designation escapes me at the moment), one disassembled. No linkage or filters... $500 plus shipping... how about that? Half-price!
Btw, as the only one to have driven all three of the 200+ mph Stude-powered Avantis, that kind of power is NOT available with "bolt-on" antique speed parts, I can well assure ya!
HEY ! ! ! Quit braggin on having driven all those fast Avantis. Some of us have tender egos. I'm jealous.Originally posted by Xcalibur View PostI have a Stu-V with the larger ports and front-facing 2-bbl carbs. It has two of the the correct early 2-bbl carbs (designation escapes me at the moment), one disassembled. No linkage or filters... $500 plus shipping... how about that? Half-price!
Btw, as the only one to have driven all three of the 200+ mph Stude-powered Avantis, that kind of power is NOT available with "bolt-on" antique speed parts, I can well assure ya!sals54
You probably have room for a turbo, mounted above the water manifold. exh. manifold's flipped over to feed turbo.better yet use a 259 or a 289, simpler fuel system to work with. if you want to keep the 232 normal hop up practices and a reground cam will probably do the trick. lots of good ideas, so off you go!!! Luck Doofus
That Ebay triple deuce intake is a Caddy intake.
It will bolt on, but.......
Originally posted by shifter4 View PostHTIH (Hope The Info Helps)
It's been suggested to use 259"/289" heads and that's important if one wants max performance.
As a nod to the old school here, the 232" is a nice-driving and torque-producing engine. Since 232" pistons are NLA, one bores it to 259" and tunes it accordingly, any more money mostly buys bling.
Yes, the two carb intakes look trick and go for $500 or less more often than they sell for $1000 or more.
Yes, there are still finned aluminum rocker covers and valley covers available.
Yes, billet aluminum distributors are available.
No, there are no headers available. Dave Thibault has aluminum repops of the R3 exhaust manifolds which look trick but they're $600 and add zero horsepower to a street engine through the mufflers.
jack vinesPackardV8
Well sir , we've given you a fair amount of info here .Originally posted by Bill-W View PostHi All, I have searched e-bay Craig's list and several other sites and I can not find speed parte for a 1951 Commander V8, or any other studebaker. I know a man who has a 2 carb manifold and he wants $1000 for it. It is the only speed part I have found. It looks so tall that I wonder if the hood would close? Air cleaner ? What is it worth? Bill-W
Will you at least respond , or acknowledge that you've noticed that , or ask more ?Bill H
Daytona Beach
Cast iron repop R3 exhaust manifolds are available from Studebaker International.
Also some AFB/WCFB intake manifolds are available from Studebaker International
Originally posted by PackardV8 View PostIt's been suggested to use 259"/289" heads and that's important if one wants max performance.
jack vinesHTIH (Hope The Info Helps)
Since our OP is new to Studes, it's important to remind him the early aftermarket intakes were designed with small ports to match the '51 - '54 232" heads.
To use the '55 and later Studebaker 4-bbl intakes, R3 exhaust manifolds, the really well-done SBC adapter flanges and Jeff's beautiful modified iron Stude and aluminum Mopar intakes, all require '55 and later heads.
jack vinesPackardV8
Well, if your Stu-V 2-bbl setup is still for sale, I am interested in purchasing it from you.
Rich G.
