Avanti Nu-Relics Power Window Installation.
  • Body / Glass: Avanti Nu-Relics Power Window Installation.
    Finally decided to remove the manual window regulators from my 74 Avanti and install power windows. I bought the Nu-Relics units from Bob Ziff and between the instructions that came with the units and the Avanti power window video on youtube the installation went pretty well.
    A few thought to leave for the future to help anyone else that may want to do the same.
    - The video on youtube says you need to remove a ridge from the interior of the door for clearance. That ridge runs from the bottom of the door to the top and it needs to be removed completely from the bottom to about 6 inches from the top.
    The best saw I found was a HF electric body saw with a fine tooth bi-metal blade. Why? Because you need to do all the cutting by feel and this tool is slow enough and the teeth fine enough to not take off a finger.
    - Put the wiring in next. The instructions suggest running a screw through the door enough so it marks the jam to position the holes for the plastic conduit. Good luck with that approach as the door is double walled with a space between.
    I decided where I wanted the wiring to come through the jam and then futzed with the conduit enough to see where I could position a hole in the door edge that I could reach with a drill and not stretch the conduit with the door open. A picture below will show where I located the conduit.
    - Before the mechanism is inserted into the door, put the two bushing into the window channel. I stuffed a small wad of paper towel into the end of the channel to keep them from falling out.
    - After the mechanism was inserted into the door and the electrics inserted, I found that it was easy to pop the pin into the guide that moves in the short channel attached to the door and then bolt the mechanism to the door. A couple of ice picks or small screwdrivers will help hold it in place before you start the first screw. Be sure the small channel is greased with red bearing lube.
    - I left lubing the window channel and gears until the mechanism was completely installed. Popping the pins into the bushings when pretty well, you just need to find the sweet spot where the pin closest to the motor will have clearance. That's why it's nice to have the electrics wired if only to a separate battery.
    A couple of shots.
ID:	1757918 Click image for larger version
ID:	1757919 Click image for larger version
ID:	1757920 Click image for larger version
    And they work also.
    Thank you for posting a good description of the work required and your experience with the product.
      Hi Bob:
      Very informative and helpful, however, I have a different situation. I'm working on a friend's '63 Avanti with manual windows and the driver's side regulator appears to be 'shot'. If the manual regulator from your driver's side is in good, usable condition and you don't plan on keeping it AND if it will fit a '63, please let me know how much you would want for it.
      Thanks, Howard
      Howard - Los Angeles chapter SDC
      '58 Packard Hawk. A partially restored car that was not completely assembled.
        Well done, power windows are so nice.
        61 Lark
          I guess that you had one of the few Avanti IIs without power windows and now you don't .
            Don't forget to clamp the internal wiring away from the gears. I have done three Nu-Relics installations. I also drill a hole in the inner panel, and run a long screw with a spacer to hold the motor from flopping around inside the door. If doing an older Avanti, the "Ford" switches are near an exact match for the Studebaker . (In looks, not in wiring or function)
            Bez Auto Alchemy
            573-318-8948
            http://bezautoalchemy.com
              At this age, convenience overwhelms uniqueness. As opposed to factory unique, mine is now Bob unique.
                Good points Brad. I was curious about the motor location. I had planned to just add a rubber spacer to cushion the motor but I'd rather have an experienced solution. Would you care to share a few more details on the spacer install?
                  Originally posted by brngarage View Post
                  Hi Bob:
                  Thanks, Howard
                  Howard PM sent - Bob
                    Believing that those that have done it before know what is required, I decided to add a brace to the regulator motor.
                    For good, better or worse, here it is.
                      That will work fine Bob. I just used a 1/4 x 20 stove bolt, and a nylon spacer from the hardware store.
                      Bez Auto Alchemy
                      573-318-8948
                        In case Bob decides to sell the manual regulator he removed (driver's side is what I need) does anyone know for certain whether the '74 regulator will work in a '63 Avanti? Thanks.
