Today, I replaced the 56J's ignition coil and ballast resister with new ones from NAPA. I cannot recall when the old coil was installed, but it said, "12 VOLTS, need to be used with external resister". The new coil is NAPA #IC7, and is stamped 6 VOLTS.The old ballast resister came from SI, several years ago. The new resister is Echlin #ICR-23, rated at 1.2 ohms. Neither of the resisters look anything like OEM.
Looking in the Shop Manual, I see the resister is supposed to be rated at .665-.735 ohms. But I cannot find what voltage (12 or 6) the coil is supposed to be. The closest resister I can find to the OEM spec is MSD 8214, which is rated at .8 ohms. But from what I have read else where, the resister is to be matched to the coil. With only modern/aftermarket coils and resisters available, matching them seems a crap shoot (unless they are bought in a set). Guess I will just go with the new NAPA parts from today.
Also, reading a 1956 Packard Service Bulletin, it looks like back then, matching coils and resisters was considered very important. The bulletin cautioned about mixing Delco and Autolite resisters, rated at 1.52 and .665-.735, respectively. Per the Bulletin, the lower the ohm rating produces a hotter spark at the plugs, but if too hot, it can shorten the life of the points, plugs or coil. OTOH, if too low, the spark is too weak, and leads to hard starts, misfires. etc.
Yep. it sure was fun today, climbing a learning curve about coil & resister matching.
