I have a 57 289 connected to a flight-o-matic.
This engine was newly overhauled with new US made bearings.
It has a rod in the front of the engine that knocks when the engine warms up.
Already cleaned and replaced the oil pressure regulator.
I may need to get new rod bearings and grind the crank that is .020 under to .030 under unless there is another cause.
My question is: can I remove the crankshaft without removing the transmission from the engine?
I would think so, but I haven't dug into that yet.
Can the torque converter plate bolts can be removed then slide the converter back?
I don't want to pull the engine for this.
it might be possible but a lot more work than just taking off your shoes first.
