Master Mechanic Carter AFB and WCFB Jet Size and Rebuild Information
This is a sticky topic.
Here is where I extracted the pages from to make a simple one document.
http://restorecarsclassifieds.com/wi...earch_kind=and
When you get here, you can change the search criteria. Massive amounts of information for a whole lot of cars..
I compiled this document for 1963, which included the T-10 and the SN60 Supercharger rebuild instructions.
Thanks - looks like a great resource!Originally posted by SScopelli View PostHere is where I extracted the pages from to make a simple one document.
Clayton Restorations Specializes in Restoring Pre-WWII Senior Classic Cars & Vintage Cars. Top of the Line Premium Antique Auto Restorations in Castle Rock, CO
https://drive.google.com/file/d/0B_w...ew?usp=sharing-------------------
Daddy always said, if yer gonna be dumb, you gotta be tough & I\'m one tough sumbiatch!
Just remember that this info is 50+ years old.
Gas has changed. Exhaust restrictions have changed.
Just don't treat it as gospel.
Treat it as a good starting point.
A good vacuum guage and A/F ratio meter will help dial you in to todays realities...HTIH (Hope The Info Helps)
Agree Jeff, it will help establish a return to the baseline. Also you have to search eBay to find some of these Jets/Rods as the numbers have changed, and the Stude ones are not readily found even in vintage Carter "Strip Kits"Originally posted by DEEPNHOCK View PostJust remember that this info is 50+ years old.
Thanks for stating this.
Carter AFB Service Manual
I've scored another resource for rebuilding the 63-64 Carter AFBs for R1/R2 application..
This is really detailed and is an actual Carter document..
This is on my google drive..
Cater old 120-xxx to new decimal size chart.
https://www.carburetor-parts.com/Car...rt_ep_753.html
- Likes 2
These four barrel carburetors just look intimidating however they are not that complex to use. Most if not all of these carbs out of the factory do not need any "adjustments". Float levels should not need to be touched for its life time (unless somebody has messed with it), Idle speeds and high speed idle should not need to be touched. These adjustments are dependent on no vacuum leaks, if you have a vacuum leak and try to perform these adjustments, there is no telling what you will end up with. The proper operation of the high speed idle is dependent on proper operation of the choke heating system. If you mess with this and the heating system is not working right you will never get it right. In older carburetors jets can wear out oversize, oversize jets can cause erratic behavior and no amount of adjustment will fix it. Accelerator pump travel has three possible positions usually the center position is used. In situations of cold temperatures and high humidity carburetor ice can form down the throat and no amount of adjustment will fix this, just time and an elevated temperature. Adjusting the carburetor to counter this condition will only make things worse. The best cure is a block heater. Contaminated fuel can cause many unwanted issues and again adjusting the carburetor will not fix this. Sometimes disassembly is required to remove the contaminants and an upstream filter is your best counter. Different areas of the country, different altitudes and humidity content can require different positions on the adjustments, usually very limited. For the most part these carburetors do not NEED to be touched.
We use the term "vapor lock" too frequently for a variety of conditions. Carburetors do boil over from time to time causing the engine to die and the only cure for this condition is time, adjustments won't fix it. This condition is usually the result of a compromised cooling system or heat riser, and no adjustments will fix this. After the engine cools down and all the excess fuel has evaporated the engine will restart with no problems an run favourably for the remainder of the trip, Therefore it must have been a "vapor lock". Compromised cooling systems, vacuum leaks and contaminated fuel are your worst enemies (and carburetors in the hands of unskilled operators).4 Photos
Thanks for posting the info. Looks a lot like pics from my National Service Data books. The one 1964 even covers the tilt wheel in the Avanti. That came in handy when I had an issue with the turn signal cable and switch! They include all makes and models. I can email any info if requested but still need to figure posting here.
Rob in PA.
I'm not sure this is the correct thread for this question, but I've pulled my Carter WCFB for a rebuild, and the mechanic asked about the gasket for the intake manifold. I took these photos and wondered if that was the correct carburetor/intake manifold gasket. Unfortunately, I don't have a photo of the bottom of the carburetor.
I estimate the thickness to be between 1/32 and 1/16. I'm guessing it was initially 1/16 and compressed to 1/32.
I will, of course, remove all the old gasket material from the manifold before installing the new gasket and the rebuilt carb.3 Photos
- Likes 1
