Hi guys,
I'm tired and frustrated; spent a good part of the day trying to get my FIRST king-pin "Pin" and bushings in the upper control arm on my '57 GoldenHawk. I have the Spreader Tool (see photo) from SDC vendor, I have it located exactly where it is shown to be in the Shop Manual (and the only place it will fit). I spread it 0.015", and the spreader stays that gap (and the section of the control arm directly in contact with the spreader of course), but the bushing receiver area tightens in more than it was without the spreader... I've tried to put the tool directly on the welded bushing receivers (where the bushings thread in) to keep that area from moving but there is just not enough room.
I finally decided to go all the way and torque the bushings down, and when I finish and remove the spreader tool (still 0.015 and goes back to "0" to remove), I can barely move the kingpin, it feels like I'm pumping a floor jack with one hand and lifting a heavy car. Both bushings take grease (squirts out one area of the seal), but just doesn't seem right that the BOTTOM of the control arm should collapse in, with the spreader "per factory procedure" and location. I've read about people making their own tools, I'm not capable of that (don't have the equipment to be making bar-stock thickness holes and such). I thought about a bolt with nut to back off and hold the bottom, but that kingpin is in the way of anything. From what I can see, you need to put the spreader where I have it (and the Manual shows it). What am I doing wrong, or AM I? Is this simply how it works originally? And it SHOULD be this stiff right now? If the lower control arm bends like this I won't be able to rotate that little "support", not having the leverage I do with the long kingpin..... Appreciate your feedback. I'm already "making metal slivers" as I torque the bushings in; afraid I'm going to ruin my NOS arms at this rate, if I have to retry much more... Thanks!!
Barry
Barry
