Received a call today from the machine shop. The bores cleaned up nicely at .030 over, however a cavity opened up in one of the cylinders. The machinist described it as an air pocket, and said the only way to repair it would be to bore it .125 over and then insert a sleeve. I told him to go ahead and sleeve the one cylinder.
Is such an occurrence (a cavity or air pocket in the casting) at all common? Just curious.
My next step is to bring him an oversized piston so that he can hone the cylinders to size, bring an intake and exhaust valves so that he can machine the valve seats to the proper height (is this a common procedure?) and bring him the camshaft so that he can verify that the cam bearings are properly installed/aligned.
That's all for now!
Cheerio,
Brent
That's all for now!
Cheerio,
Brent
