Where to get correct heater hoses for 1957 Golden Hawk?
  • #16
    Rudy, I believe 5/8" is what your car came with, but it may now have a mix of 5/8" and 3/4" due to the passing decades of folks using what was available. It is easy enough to use plumbing adapters to step-up or step-down hose sizes, as needed. For example, if the heater core is 5/8", and all else is 3/4", use adapters to connect to the core (especially since the core is the most expensive part in the heater system). The WP manifold fitting may be easier to just switch out to matching size; they are cheap, and screw out & in. If you need to replace that nipple, consider an 'L' shaped one, as used on later Stude Hawks, for reasons already mentioned above.
    In a pinch, a 5/8" hose can be used on a 3/4 nipple, or visa-versa, but consider that only a temp measure.
    • #17
      Hello Joe
      Thank you for the advice. So I will just put there a 3/4" hose again. Difference between 3/4" and 5/8" are not that big to notice.
      Rudy
      • #18
        Originally posted by Swiss-Goldenhawk View Post
        Hello Joe
        Rudy
        Not that notice-able, IF you locate the adapter someplace inconspicuous. For example, under the car, about 6" from the heater core. The adapters are small, and fairly common around here in hardware stores.
        • #19
          Hello Joe.
          I drained the system and this time measured the inner diameter and guess what - it is in fact a 5/8" hose. Those are quite easy to get online.
          Have a good time.
          Rudy
