How many presto-lites were used ?
  • How many presto-lites were used ?
    Besides the Avanti type alt.,was there only one housing style presto-lite.I was going through a pile of them and found one odd looking,I'm sure others used them back then.
    Joseph R. Zeiger
    Yes there were only Two used by Studebaker, one adjusting Ear and Two.
    Many other types were used on stationary equipment, fork lifts, tractors etc.
    I have seen Motorola's used as a replacement that look a lot the same. Even those Nipondenso/Toyota/and Honda Units do look alike, but if yours says: Prestolite, then it is for something other than Studebaker.
    Many Gen. Electric Shops have a Pile of them.
      Thanks Rich. We've had so many Studes here over the years,this one must have been rigged up to one of them as that's likely the only way it would've gotten here.
      Joseph R. Zeiger
        The 1966 models only used a Prestolite alternator with a single thick mounting ear.
          Thanks Jerry,this one has the thick mounting ear.
          Joseph R. Zeiger
            Joe
            I remember seeing one on a 60's IH Scout. Don't know if it was original.
            Rob in PA.
              I'm glad I saw this. I'll need a 'double ear' alternator to rebuild so I have a spare. There is a local yard that has a few Stude's in it and I'll know what to look for.
              Tom - Bradenton, FL
                Thanks Jerry, I guess we hear that here every now and then: "You learn something new every day"!
                I have had hands on experience with a whole lot of Studes everything from '54 to '64, but not so much CanadaBakers!
                I now (recently) bought and drive a '66 Cruiser, but knock on wood, it has required very little and I never noticed any difference in it's Prestolite, that might be a good replacement for the weaker ones.
                  That one was only used on the Jet Thrust Powered Larks, R1 Hawks, Avantis and Zip Vans, in an Avanti with the Three contact Regulator it could put out 40 AMPs, but in Lark/Hawk with the Standard Voltage Regulator (one contact) they only produce the same 35 AMPs as the Standard "One Ear" Model.
                    Rich, is this a 'single ear' or a 'double ear'?
                    Tom - Bradenton, FL
                      Single ear - you would quickly recognize the double adjusting ear version if you saw one.
                        OK, learn something new everyday...
                        Tom - Bradenton, FL
                          You can just barely see the TWO EAR Prestolite H.D. 40 Amp. Alt. in this R1 '63 Hawk.
                          It also has a different cooling fan on it with a solid flat metal ring (shield) in front of the blades.
                            Thanks Rich. A picture is worth a thousand words...
                            Tom - Bradenton, FL
                              Look in the parts book, '59-64, to see all of the different alternators listed, 55 & 60 amp, for fleet and taxi service. I don't believe the statement that only 2 were used is correct.
