Good morning all. Does anyone know where i can buy or rent a pitman arm puller that will work on a '61 lark. I have tried the ones pep boys sells and the one from auto zone. Thanks for your help.
Pitman arm puller
Most all commercial pitman arm pullers will not work on a V8 Studebaker Lark in the car. They are too long. I had to build one to work on my Lark. It is a short "U" type puller with a fine thread set screw. A commercial puller will work with the engine out or if you unbolt and turn the steering box to gain clearance. I can post a picture of the one I built if you would like.
Jimjames r pepper
I've always used the type sold at Harbor Freight. But now I can't remember fer sher if they can be used while the engine is still in the car. I know they break sometimes, but they are so cheap, I never really cared about that. Anyone know if this style works with engine in car?sals54
Originally posted by jpepper View PostMost all commercial pitman arm pullers will not work on a V8 Studebaker Lark in the car. They are too long. I had to build one to work on my Lark. It is a short "U" type puller with a fine thread set screw. A commercial puller will work with the engine out or if you unbolt and turn the steering box to gain clearance. I can post a picture of the one I built if you would like.
Jim
My one and only experience with removing a pitman arm was a long time ago and I probably broke every rule, but... I needed a complete power steering setup to install on my '64 Daytona Wagonaire. Yes, I had foolishly not ordered it with power steering. Anyhow, I found a wrecked '64 Daytona hardtop in a local salvage yard. I took my tools along and got the nut off the arm, but I couldn't figure any way to get that arm off. I went to the salvage yard man and told him my problem. He grabbed a large crowbar and a heavy hammer and told me how get it off. He put the crowbar against the pitman arm just under the shaft, put pressure on the arm, tapped the top of it with the big hammer and the arm came right off. I took the complete power steering kit home, used the same technique and got the standard steering pitman arm off the same way-piece of cake. Installed the power steering system and it's still on there this many years later.Paul Johnson, Wild and Wonderful West Virginia.
Originally posted by bensherb View PostPlease do, I'm interested too.
Jimjames r pepper
James , I am about to install power steering in my 58 golden hawk and wonder if you would let me borrow your tool
I will pay for postage both ways to Raleigh < NC if you can help me
Thanks , Joe Parsons cell 330 502 5930
Joe Parsons
There are "low-profile" clamp-action pullers available, but they are much more expensive than the typical ones normally seen. An example is #68800 puller made by SP Tools. There are several new ones available on eBay for $141.00. These might also be available for loan or rent at a local auto parts store.Mark L
I bought a puller locally, I think at AutoZone, and per suggestions on this forum, I modified it as shown:
I bought a hardened bolt with the same threads, (actually I bought a couple different lengths) and installed it backwards. You have to use a box end wrench and put that over the bolt before using, and lube the bolt head with some grease too. It worked great, and the arm came right off!
- Likes 1
Bruce, did you have any issues with the bolt you were turning with the wrench trying to walk or slide off the end of the gearbox shaft? Also, did you need to remove any other items, like the starter, to get the puller in place?Mark L
Originally posted by 58 Hawk View PostJames , I am about to install power steering in my 58 golden hawk and wonder if you would let me borrow your tool
Thanks , Joe Parsons cell 330 502 5930james r pepper
