Does anyone know what years had glow in the dark gauges?
Does anyone renew the glow material, so they work better?
Has anyone tried the ebay glow paint?
I just bought the gauges in the picture, because they are better than the ones in the Land Cruiser I just bought, but you can see the oil needle is very dark, and no longer shows up at night. The "F" on the gas gauge also doesn't glow.
Here is some information I found for glow paint on ebay:
Glow Inc.'s glow in the dark paint is made from Grade 0 Strontium Aluminate pigments in a durable, high adhesion acrylic medium. Two pounds of top grade pigment per gallon of medium produces the brightest glow in the dark paint available. Glow in the dark paint absorbs bright light as energy. When placed in the dark, glow in the dark paint releases this energy as a glow. You can repeat this cycle millions of times. Applied properly, glow in the dark paint will lose 5% of its brightness every 10 years. Any light will charge the paint. Direct sunlight, high wattage bulbs, or black lights are needed to obtain the maximum glow.
Glow in the dark paint is often used for professional murals and to paint glow in the dark stars on ceilings. Due to its durability, it is also perfect for painting glow in the dark fishing lures and outdoor signs.
Each color has a different brightness and glow duration. The Green V10 is the brightest and will glow throughout the night. Glow Purple does not glow very brightly and requires a high wattage charging source. Check the brightness rating for comparison.
Sealing coats are not needed. Paint over white surfaces when possible.
It is critical that you apply this paint at least 1/16" thick (4 oz per sq. foot) for proper glow and a smooth appearance.
Glow in the dark paint is shipped ready to use with a standard brush or roller. Thin with acrylic thinner or a tiny amount of water. Clean up with soapy water.
