Guess I will start a build thread on this. Not much to contribute on my first post.
With apologies to Ron and the other Purists, for a variety of reasons I am installing 350 Chevy engine and NP 542L in my 49 2R16A.
Will post some pics of the progress. Going slow right now. Using the cross member out of the 2 ton (C50) Chevy truck that I pirated everything else from. Will either use the front cross member from the Chevy truck or fab one. That way I can use the giant front truck motor mount assembly. See attached pic.
Very stable. I am removing the "K" type member from the front of the Studebaker. Man, those rivets are a bitch to get out. I grind the heads off and STILL cannot knock them out without center drilling them.
Considering options for clutch linkage. I REALLY like the factory pivot rod going through the bell housing. I am taking car to have the crank centerline of the Chevy exactly where it was with the flat head six. Got to thinking; maybe I can modify the truck bell housing (cast iron) to accept that pivot rod and use the factory linkage. Seems it would be much cleaner than fabbing up bell crank linkage for the Chevy "Z" bar type linkage. Just have to see where the factory stuff lines up when I get this all mocked up.
Anyone ever modify another bell housing to accept the pivot type linkage?
