So, I've read numerous stories about putting X or Y fluid in the cylinders of a stuck or possibly stuck engine, but today pointed out to me I've never read what happens to whatever fluid you put in the cylinders before trying to start a stopped motor.
Long story short, as I went to torque down the head bolts on my 2R17A, I was going to install the carb and air cleaner but as I took out the rags I had stuffed in the carb manifold I noticed red fluid on them. ??? After a second dip it hit me, I used acetone and ATF in the cylinders to ensure the cylinders weren't stuck to the walls.
I sucked out about 1/2 to 3/4 cup of ATF from the manifold, but I'm sure there's a little more in crannies, plus, I have a 2 speed rear axle, so this may have got into that plumbing.
Also, I noticed some crumbs of black material inside the manifold on the bottom. I picked some out and best as I can tell, it's likely carbon crumbs.
I sure hope I don't have to pull the intake manifold to clean it out, but....
Clearly, I have good compression and rings and essentially none of the ATF made it past the pistons and into the oil pan.
