Leaf spring clips
Tags: None
That's my plan -- I just thought I'd check here first to see if anyone was sitting on top of a truckload of NOS suspension parts! :-)
What karterfred88 and Alan said. I had the same delimar with my 59. I was able to get all the metal banding from work and a tool to do it and I was able to reuse the rubber. I did not, however, go this route. As I was not keeping the whole car original there was no need to keep this style of clamping device for the rear springs. I added an extra leaf and used some more modern clamps from the local spring manufactures.
Len
Leaf Spring Clamp Rubber
I used these on a 56 Power Hawk and they worked great Check EBAY search (Leaf Spring Clamp Rubber Liner Set used on Ford Edsel) cost $15 S/H included and enough for a car and a half (6) rubber pieces. You will need to leave the stainless band on your springs and scrape or pull out the old hard rubber pieces. Good Luck
