I have an old frame dimension diagram from an old Mitchell manual that shows a diagram for a 1959-61 Hawk. Can anybody tell me if these measurements would be the same on a 1962-63 Hawk?
1959-63 Hawk Frame Dimensions
Tags: None
Originally posted by gegrunt View PostI have an old frame dimension diagram from an old Mitchell manual that shows a diagram for a 1959-61 Hawk. Can anybody tell me if these measurements would be the same on a 1962-63 Hawk?BP
There is one bracket on each side of the frame on the later GTs that is not on the earlier 50s, otherwise the mounting locations are the same. The GTs also use a longer rear spring and locate the back mounting hole for it further back on the frame.
