It looks like I have a truck flywheel for an 11" clutch, in that the pressure plate bolt circle is 12 5/8". Having read several threads here about clutches, if I understand correctly, a V8 car flywheel would be setup for a 10 to 10.5" clutch, and have a bolt circle of 11 5/8". Is this correct?
Also, if I should decide to run the truck setup, will the 11" pressure plate work with a passenger car bellhousing?
Thanks,
Joe H
Thanks,
Joe H
