Is the rear port on a modern Edelbrock 500 okay for a PCV valve or do you have to use the port/nipple on the front? Are they not the same?
PCV Connection ?
Edelbrock will tell you to drill and tap the front of the carburetor between the full-time and ported vacuum connections for the PCV. It supposedly eliminates some problems caused by installing the PCV like Carter originally did. I'm not sure of the reason why but if you contact Edelbrock tech department they can explain it and walk you through it.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
