View Full Version : How To: Measure Belts With Accidental Accuracy
RottenRodney
05-21-2007, 08:11 PM
Did yawl catch it last week when I stuck a size-twelve Red Wing in my mouth? Yeah, I tried to blame it all on Evelynn Wood, but now I'm back to face the music in a blatant attempt at self-redemption.
The subject was belts, and how best to measure for fresh ones. Granted, it isn't usually necessary to achieve deadly accuracy when measuring for belts, but sometimes things get a little tight in early engine compartments. Some of us like to stuff that proverbial ten pounds of poo in a five-pound bag. Yawl know who you are.
Now before I dig in deeper; I should go on and say that I've been playin' with Studes (and some other brands) long enough to know better, but for whatever reason; I didn't know how to properly measure for belts until recently. The last time I tried, (about three months ago) I fashioned a mock-belt from wire and took it to the parts guy. Well, that didn't work, so I went back the next day, and the next day, and the next day, until I finally just lucked out. Now some of yawl are laughin' at me, and that's arright. I have a good friend who is what I'd call a "real mechanic" and he laughed a little too -- then he shared his measuring method with me. "Keep some old belts around. You can always use one that's too long, just cut to fit -- there's your sample." Now as Tom pointed out here last week; someone's got to hold the sample-belt together while someone else sneeks up and measures it. That's about the only drawback to the 'cut to fit' method -- it takes four hands.
I like to splatter paint around every now and then, so I've got the high-quality green maskin' tape from 3M on the shelf at all times. It'll adhere fairly well to a belt if wrapped tight enough, but Tom also pointed out that slippage might be difficult to see beneath tape. Then he suggested staples as I recall, this sounded good so today I thought I'd give his method a try. "Where's the T-50s? I know they're on this shelf somewhere... Maybe if I get some other stuff out of the way... Let's see... Move all these zip-ties... Now move all this shrink-tube and... Doh! SHRINK-TUBE!" The 'hot tip' was right in front of my nose.
http://i25.photobucket.com/albums/c88/RottenRodney/100_3923.jpg
This works like a Studebaker Champ! Slip it in, hold it toghther, (single-handedly) while using your remaing free-hand to pull the trigger on the heat-gun. This works exceptionally well with the late-model knobby-tread belts. Ours did not slip. Oh, now you're thinkin' this won't work on smooth belts, right? Carve some grooves in the ends -- now you have the knobby-tread design workin' for you too.
This simple accedental discovery made my day go a little easier. Hopefully, it'll help someone else down the road.
Now where's that 'spell-czech' button? There's gotta be one around here somewhere... RR
Faster than a rusting bullet... Gopher Grove, CA
lstude
05-21-2007, 09:05 PM
quote:Now where's that 'spell-czech' button? There's gotta be one around here somewhere... RR
Good info. I don't think the forum has a spell check yet. It does put a red line under misspelled words. What I do sometimes is copy what I have written and paste it on Microsoft Word and use the spell check. Then I copy the corrected wording and paste it back on the forum.
Leonard Shepherd
http://leonardshepherd.com/
http://i129.photobucket.com/albums/p235/lstude1/Mein64DaytonaatBradfieldssm2.jpghttp://i129.photobucket.com/albums/p235/lstude1/52Commanderoutofgarage4-3.jpg
JDP
05-21-2007, 09:13 PM
It does have a spell check BTW.
JDP/Maryland
63 GT R2
63 Avanti R1
63 Daytona convert
63 Lark 2 door
62 Lark 2 door
60 Lark HT-60Hawk
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
lstude
05-21-2007, 09:31 PM
quote: It does have a spell check BTW.
How do you use it?
studeclunker
05-22-2007, 08:21 AM
Great idea, Rodney! Thanks!:D Not that I've ever used a shrink tube in my life, nor do I know where to get them. FLAPS? Now, where did I put that heat gun...
http://i16.photobucket.com/albums/b18/Studeclunker/december%2006/HPIM0234.jpg http://i16.photobucket.com/albums/b18/Studeclunker/56%20Parkview%20Wagon/56wagonleftfrontclipped-1.jpg
Home of the famous Mr. Ed!
Lotsa Larks!
Ron Smith
DEEPNHOCK
05-22-2007, 10:12 AM
How long can you run them like that?[?];)
quote:Originally posted by RottenRodney
<snip>
Now move all this shrink-tube and... Doh! SHRINK-TUBE!"[/i] The 'hot tip' was right in front of my nose.
http://i77.photobucket.com/albums/j54/deepnhock/Jeff%20Rice%20Studebaker%20Pictures/1937StudebakerCoupeExpressJeffRicee.jpg
DEEPNHOCK at Gmail.com
Brooklet, Georgia
'61 Hawk (project)
RottenRodney
05-23-2007, 12:09 AM
DEEPNHOCK, that's a goood one! You shoulda been here at the test-lab today. Black shrink-tube is barely detectable...
