Pics! If it's an early 61, it's got the flathead six still and later in the year, they switched to the OHV engine. As for driving habits, I credit the 70s gas crisis, as well as learning to drive a 20 year old car, for my habit of driving to the car instead of making the car drive how I want it to move.
As for your driving situation, I guess, you're already tuned into driving slow and steady at least!
I don't know about the speedo issues. Mine is off too. Basically, I'm 10mph under
when I pass a radar sign and then look at the speedo. I've also noticed I'm 3 tenths higher on my odometer going by the highway mileage signs. I believe the issue is most likely a matter of getting the correct speedo gear tooth and swapping. Off the top of my head, I know the 2 speedo gears are listed in the Stude Lark manual, but I don't have one handy to say which 2 there are. It's not something high on my priority list, since I drive it 10 mph off and just live with it. Some day I'll remember to crawl under there and count the teeth on the gear there.
I did buy a cheap VDO tachometer and mounted it on the steering column just so I'd have an idea of what a wound out motor sounded like. I still rarely drive it at 3K and my redline is 3800rpm. IIRC, hp and torque numbers for the V8s are around 4500rpm and the motors can rev higher, but likely start floating valves around then. ymmv.
