Originally posted by karterfred88
View Post
I set toe in/out by coasting the Stude to a straight stop, on level concrete, with steering wheel centered, and GOOD tires on the car. I used to use the string, per the Shop Manual, till I got the hang of it years ago. Now, I simply sight along the outer edge of driver side tire, and align it with the rear tire, where the rear tire just barely disappears. Then I do similar with the passenger side, but a little extra past disappearance of the rear tire, for a little toe in. I then test drive, and if it pulls to one side or other, I play with the passenger side toe in. If not satisfied, I swap front tires, side to side. Repeat the passenger side toe in, if necessary.
I set camber by simply maxing the adjustment on the cam. I have learned from experience, excess positive camber on a Stude is only possible if its a, "low rider".
As with camber, I set the cam for max caster, because you cannot achieve too much, "rake" on Stude king pins. I compare caster between sides, and if needed, give up caster on one side to come as close as possible to matching the other side.
To read caster and camber, I use a bubble vial, bought from JCW many years ago, that is amazingly accurate. But I seldom use it anymore. As explained above, just set both for max, and forget it.
I usually have to rotate tires once in their lifetime, but often because the rears wear out before the fronts.
