Have managed to install a 350TPI engine & 700R4 from a 89 firebird without any problems in my 65 Wagonaire. The issue is the steering. Do I change the stock exhaust (rear exit on the left side) to say shorty style headers to allow access to the steering column? Would prefer to use a modern steering box so that I can use the firebird steering column as was planning to use the firebird wiring harness. Reading the threads on changing to rack & pinion has given me second thoughts on going that route. The 65 came with PS so could change or incorporate the 89 PS pump with the Stude lines? Hope a few others have some past experience on this. Have done 4 stock restorations in the past but this is my first swap of a modern drivetrain into a Stude. Thanks, Len
TPI 350 install in 65 Wagonaire
Unless you are ready for some major front end changes, there isn't a "bolt in" "modern steering box" . I've been researching this for years. The original steering setup, using a reach rod going front to back, isn't easily useable with a "modern" steering box. Most were designed to move the linkage left to right. Turning it on it's side and using a reverse gearbox would work--if they weren't so wide and if they didn't have the pitman shaft on the wrong side of the worm after doing it. If you have exhaust manifold clearance problems now, they will only be multiplied changing the steering gear. That being said, a steering box from an Avanti with a rag joint connector could be used with a modified upper column shaft to change that. Alan, on here, has a way of converting the front to a cross-steer setup, but I'm sure it isn't a bolt in operation, as he has done some pretty fancy Stude conversions.
The center dump 60's era "Ram Horns" are what Studebaker used. I have a 85 Corvette L-98 in my '64. The pictures tell the story better than I can. The cast manifolds are available in 2.5" if you feel the factory 2" outlet is too small. In my case the L-98 cam is tuned for torque, not RPM and it kind of chokes the engine short of 5,000 RPM so the 2" is acceptable.
Did you keep the TPI? Or did you swap manifolds and go to a carb like I did (bought the engine as a long block, not complete)? It takes a bit of modifying the Batwing to get the 700R4 to fit. Would like to see pictures.Last edited by wittsend; 05-21-2016, 09:18 AM.'64 Lark Type, powered by '85 Corvette L-98 (carburetor), 700R4, - CASO to the Max.
Originally posted by wittsend View PostThe center dump 60's era "Ram Horns" are what Studebaker used. I have a 85 Corvette L-98 in my '64. The pictures tell the story better than I can.
Originally posted by sals54 View PostYour 65 would have had a Chevy V8 installed as factory. Why not use the original exhaust manifolds? Were they different bolt patterns from those years?--------------------------------------
