Yes, I know I shouldn't use an ammeter in 2016, but I purchased this matching (photos attached) set of gauges to replace the gauges in my 1957 President, which came with 2 colorful gauges (which no longer worked) and 2 idiot lights for temp and oil. I already tried direct wiring the switched "ign" wire (black stripe on 12 ga white wire) and plain black wire, which, predictably resulted in a GROUND SHORT. I did get some readings from the fuel and temperature gauges, but they are not correct. The temp light comes from a single wire hooked to the sender on the left rear of the block. (289 V-8).
I can't read a wiring diagram (that is why I became a surgeon, and not an engineer) although I have screen shots of 57 Clipper wiring diagram. In the interim while waiting for "expert" advice (from this forum) <g>, I have successfully installed the electric wipers (with a new motor from S.I. and today I will try to re-install the original AM radio and speaker which has been restored. The lid of the dashboard is still off pending correct wiring of the gauges.
Thanks. Also included some recent photos. The car is street legal with brake, backup, and tail lights.
