Any tricks or special tool to stretch the pedal return spring that whole inch to fit the hole in the bracket near the rear of the master??? (63 Hawk )
Clutch pedal return spring install
That sounds like the clutch pedal return spring. I use a brake spring pliers. If you are talking about the brake pedal return spring, it hooks into a tab on the pedal bracket and goes forward to a hole in the frame.I remove the sheet metal cover under the pedals to get to that hole.Howard - Los Angeles chapter SDC
'58 Packard Hawk. A partially restored car that was not completely assembled.
Flex the spring, and put washers in the spring gap on the open side. then flex it the other way, and do the same on the opposite side. Then you can easily slip the spring ends over the retainers. Then when you step on the clutch, and extend the spring, the washers will fall out.Bez Auto Alchemy
