You guys ever have one of those days... [}
I pulled out all the plugs in my car for the first time and they all looked a bit lean, but zero rust and zero oil on any of them. I thought yay! Time for a good luck dance... I oiled up all the cylinders with the plugs out and was looking forward to cranking it a few times just to get the cylinders wet again...
Step 2. Insert key and promptly push ignition switch through dash. LOL [
I decided it was time to call it a night before I did anything stupid.
It should be obvious which project i'll be tackling tomorrow morning.
Do any of you guys have any tips on popping an ignition switch out of an old Commander, or possibly how to put it back in? I think the switch is similiar to the '65 Mustang I used to have where you push the switch up against the dash while spinning the bezel? I was thinking I should remove the ignition switch first because I was having a real hard time turning it for some reason. I think it would be best if I cleaned and serviced it away from the dash. The only issue is it's tight, sharp and rusty under there... and the wires don't seem long enough for it to dangle under the dash?
I also noticed that there was a strange, almost fiber optic looking light that is kind of attached to the igntion switch. Was this on all Commanders, and where would the light come out from? The light is housed in a wierd little round ball about half the size of a marble.
Any tips would be greatly appreciated!
Thanks!
Chris Salisbury
Hutto/Austin, TX
1958 Commander Starlight Hardtop
Thanks!
Chris Salisbury
Hutto/Austin, TX
