2 1/4" fuel filler hose
  • Fuel System: 2 1/4" fuel filler hose
    Hello All:
    I haven't posted in awhile, but I read all the time.
    I'm not happy with the exhaust system on "HemiS2D". Because the fuel tank is offset to the drivers side of my 53 Commander I couldn't tuck the 2 1/2" dual exhaust up close to the frame. I've decided to move the fuel tank over to the middle of the car. It should be very simple, but the stock fuel filler hose will be too short. I've looked all over the web and have not found a source for 2 1/4" filler hose. Can anyone lead me in the right direction?
    Thanks,
    Dave Davis
    Bakersfield, Ca.
    1953 Commander Regal Starlight
    \'58 392 Chrysler Hemi powered
    I think a 24713 Gates hose will do what you need
      See Filler Neck Supply for 2-1/4" i.d hose for fuel tanks. Not cheap at $2.05 per INCH! But, you CAN buy it and it will take modern fuel.
      Filler Neck Supply Co Stocks The Best Selection Of Fuel Filler Hoses Available. 45 and 90 Degree Elbows, Straight Sections By The Inch, Foot or Roll.
      Gary Ash
      Dartmouth, Mass.
      ’41 Commander Land Cruiser
      '48 M5
      '65 Wagonaire Commander
      '63 Wagonaire Standard
      web site at
        Thanks Flashback. Being a CASO I don't want to spend $30-$90 for a 3-6' section.
        I'm looking for a 10-12" section that maybe came stock on a Studebaker.
        Dave Davis
        Bakersfield, Ca.
          NAPAonline has 2.25" fuel tank filler hose #nbh1055 listed "in stock"
          $24.88/foot
          Take the old one with you, buy as much or little as you need.
          South Lompoc Studebaker
            Why not use some of the straight hose available from any parts supplier and clamp it to a piece of 2-1/4 exhaust bent where you need the fit?
            Brad Johnson,
            '56 Sky Hawk in process
              Try a good marine supply depot....they will meet all modern fuel requirements
              Bill Foy
              1000 Islands, Ontario
              1953 Starlight Coupe
                Wouldn't the simpler option be to use 2 1/4 or 2 Inch Tailpipes?
                You could use 2 1/2 Inch Head and Front Exhaust Pipes with the smaller Tail Pipes as all Studebakers were.
                Did a Factory Hemi ever come with larger than 2 Inch Tailpipes?
                  my tailpipes are 2.5", and tuck up pretty close to the tank and frame on the driver's side. I don't have access to my photos on this computer...if you want too see some pic's, let me know and I can post when I'm at home. cheers, Junior.
                  1954 C5 Hamilton car.
                    Thanks everyone. I found it at my local Napa Auto Parts. Thanks 55 56 Prez 4D for the heads up. I paid $24.19 for a 12" section
                    Dave Davis
                    Bakersfield, Ca.
                      I paid $24.19 for a 12" section.
                      ...which is $2.015 per inch. (BTW: What ever happened to Decimal Dude?)
                      KURTRUK
                        I should have mentioned that if you have a AAA membership there is a 10% discount.
                        Not on all purchases but it doesn't hurt to ask.
                          ...and, btw... who cares what size exhaust the hemi CAME with?
                            I am pretty sure Chrysler Engineering would not have used a Pipe size that would not get the most out of their High Performance Engines, so getting on the "More is Better" Train will not prove a thing, or improve a thing!
                              McMaster Carr has it for about ten dollars a foot. http://www.mcmaster.com/#fuel-hose/=wrdb8j
