Joe; I did that swap back in the early 70's. Only drove my Avanti about 100 miles. Coming up the Hollywood Freeway, just before the Sherman Way off ramp, it died, just like you turned off the key. I thought it was the module too, but after tracing everything down it was one of the wires from the pick up coil that broke off, but the plastic was still holding it together. Replaced the pick up coil and it ran trouble free for about 50,000 miles.
electronic conversion/ Prestolite-mopar
Originally posted by Alan View PostJoe; I did that swap back in the early 70's. Only drove my Avanti about 100 miles. Coming up the Hollywood Freeway, just before the Sherman Way off ramp, it died, just like you turned off the key. I thought it was the module too, but after tracing everything down it was one of the wires from the pick up coil that broke off, but the plastic was still holding it together. Replaced the pick up coil and it ran trouble free for about 50,000 miles.
jack vinesPackardV8
I know lots of Stude folks have had good experiences with the MOPAR conversion. But there's also no shortage of MOPAR folks on the internet who curse them, and have converted over to other systems. However, many blame the problems on off shore replacement parts, which is all too familiar to us too.
I worked at a MoPar dealership in the late 70's and 80's, and did replace quite a few of the ignition parts. When I test drove the car, and was checking for an ignition problem, I carried a bottle of cold water to dump on the control unit if the car quit. This would get me back to the shop where I'd install a new unit.
Originally posted by jrlemke View PostWhat is required to use the GM module with this swap?
Another Washington State Brother.
Hi Guys
I wrote this article which you can find on Bob Jonstone's site:
Anyone wishing to use the Mopar parts may find useful.
You can use just about any HEI module around but it may have different advance curve.
I did not get too hung up about a slightly different curve because the Hawk ran so much better with this conversion anyway and has so for the last 5 years.
AllanAllan Tyler Melbourne Australia
Allan
Phasing is kinda tricky, upon initial setup; as you suggested, a hole in a spare cap is the way to go. For coil, I have a GM epoxy, but was told any coil with same ohm resistance would work. That is noteworthy, since there are modern coils that look like OEM Stude, yet are designed to work with electronic ignition setups.
Again, excellent article. Thanks !
