Originally posted by PackardV8
View Post
Three speed floor shift?
Originally posted by jclary View PostI don't know how many were built, how many brands sold them, but I do know that three speed floor shift cars were available in the early sixties. I had a friend, who's father died at an early age, before I knew him. That left him and his mother alone on their rural farm. The reason I remember this particular car is that my Mom, and most women I knew at the time, wouldn't think of having anything but an automatic, no manual shift cars.
One day, Dean's mom drove up, as happy as could be, grinning from ear to ear. She was driving her brand new Plymouth Valiant, slant six engine, and a three speed manual floor shift. We were in our teens. Dean got his license shortly thereafter. When his mom was not looking, he kicked that little car around pretty bad. That shifter must have been built pretty tough, because I don't recall any problems, even after getting punished by my friend. I don't know what happened to that car, but a few weeks ago, I attended Dean's funeral. We hadn't kept in touch over the years, but it seems that he lived a pretty good life.
Before getting assigned for a year's government sponsored free trip to Vietnam (1967/68), I bought and completed a hot rod 53 Chevy truck. It was being built in the base hobby shop at Bergstrom AFB, Austin Tx. I installed an aftermarket three-speed floor shifter in it. The main thing I recall about that shifter was the nylon bushings in the shifter mechanism. When they wore, they would cause interference and hang ups. Keeping those bushings in place, lubricated, and the linkage adjusted, was critical to good service.
On the current availability of three speed floor conversions...If you find one, look for signs of wear. Make sure the linkages are tight, and not sloppy. If there are "plastic" looking bushings, try to determine if they are cheap plastic (that can become brittle and crack off) or some tougher material, such as, nylon or delrin. If you opt for metal bushings, remember, they will require frequent inspection and lubrication. Due to the location, shifter linkage is exposed to road grit and grime. Also, due to location, they are easy to neglect until problems occur.
It has been so long ago (now), that I don't recall all the details. However, I think I improvised some new bushings from copper or brass. Unfortunately, I had to sell the truck after returning from Vietnam to help pay some of my college expenses. After graduating from college, I was longing for another "old" truck when I accidentally stumbled across an "old" 1955 Studebaker truck....Have had it ever since.
Merry Christmas!John Brayton
Originally posted by t walgamuth View PostI have a three speed floor shift from a fifties corvette...56? Not sure. I bought it off ebay when I was planning to use the three speed od truck trannie in my CE. I'll sell it reasonably.
Originally posted by PackardV8 View PostThe Hurst Indy shifter is available new from Summit/Jegs/local retailers for cheap. It's not as good as the original, but with a bit of fabrication, it can be made to work with a rat rod.
First question to be answered, is your Champion from a car, with T96 tranny or from a truck with a T90 (would have T86 on the case)?
jack vines
It's an engine from a 52 Champ.
Merry Christmas,
John BraytonJohn Brayton
Originally posted by John Brayton View PostHi Guys,
I'm building a rat-rod using a 52 Champ engine and three speed tranny. I'm hoping to find a floor shift setup and avoid the column shifter. Did anyone make such a shifter?
Thanks!!
Or, just find a three speed shifter and adapt it.
Len.
Originally posted by RadioRoy View PostIt should be possible to take a top shifter from an earlier Jeep CJ and bolt that right into the transmission, if it's a T-96.
I have been (mentally, so far) toying with the idea of making a "universal" top shifter. Imagine a base which would bolt on in place of the top cover, containing a socket for the shifter stick, and some gates, etc., such that moving the stick would cause rotary motion in two cross-shafts located ahead of and behind the stick socket. On the left end of each cross-shaft would be a lever, connected by a linkage rod to the lever on the transmission case. Basically, it would be your standard after-market floor shift, but reconfigured to be mounted on top of the transmission, not behind and to the side. Yes, you would probably have to make clearance for it by raising the floor over the top of the transmission, but the expected use of such a thing would be in a customized car, so no big deal, right?Gord Richmond, within Weasel range of the Alberta Badlands
Originally posted by John Brayton View PostHi Jack,
It's an engine from a 52 Champ. Merry Christmas,
John Brayton
jack vinesPackardV8
Originally posted by evilhawk View PostI plan to put a 3-speed Indy floor shifter in my 59 with an O/D trans. Is it possible to drop it in with the trans still in the car?
Also, most Stude trannies have an inch of greasy dirt all over them. Removing and cleaning the worst of that also makes for a better install.
As long as you're headed down the slippery slope, while the driveshaft is out is a good opportunity to replace the U-joints.
jack vinesPackardV8
