Alan and MrX,
Thanks for the comments and suggestions. I was planning to change the dual nut setup to a cotter-pin/castellated nut setup, depending on whether or not the tie rod end is pre-drilled or is super-hard steel. The photos can be a little deceiving because of the weird photo angles and lack of familiar references. I'll get some measurements about the width of the Neon rack assembly as well as some clearance measurements; I didn't notice that the exhaust pipe was that close to the hydraulic line, but it might be. I'll report back.
The missing zerk fitting is already on the work list, but I think job One will still be to replace the OEM master cylinder with a 1969 Chrysler Newport/New Yorker dual reservoir M/C and to replace the old Stude rubber flex hoses with some braided stainless flex hoses in the front and rear.
BTW, my installation of some old, but gently used Koni adjustable shocks that were specifically valved in the 60s for the Avanti made a significant difference in better handling and anti-dive characteristics under hard braking. I would suggest that anyone needing shocks now strongly consider adapting some currently available Konis (for the 65 Corvette and the 1970s Camaros/Firebirds) to their Avanti.
