Does anyone have a picture of a HM-931 rear axle shaft puller?
57 Commander rear axle shaft puller
Tags: None
Look in the Shop Manual. I know that the '59 thru '64 Shop Manual shows the 'special tools' on the last page of each section. Not sure about the earlier Shop Manual, but worth a look.Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
http://partsforsale.studebakerskytop.com/
So you already have the wheel, brake drum and hub removed? Now you just need to get the axle out of the housing? A common practice is to just set the drum/hub backwards on the axle, then thread the axle nut on several turns and use the drum/hub as a slide hammer to pop the axle out.
I can scan the illustrations if you want them, but HM931 is just a slide hammer and an assortment of 3 threaded sleeves to fit all the axles. The later set J7935 looks like the same 3 sleeves, but the slide hammer is a separate item J2619.Restorations by Skip Towne
