Hi Forum,
I've read the older posts on bearing noises. That said...
1962 Hawk, 289, 4spd Borg, Dana 44, 3.31 gear, not twin traction, 97,000 miles
At 5 miles into my trip today the left rear started making so much noise I turned back to home and begged to see my garage without calling for a tow. Limped in 2nd gear at low speed and I finally reach my home. I ran to get my new nifty Kline infrared IR1000 temperature measurement tool. Popped the hub caps: Measured on the threaded spindle hub (sorry if not the correct term). I picked what I thought would be the hottest location and measured the same for all. Left rear 123F, right rear 93F, front left 83F, front right 84F.
The 30 degree Delta-T right rear to left rears tells me something is different between the 2 sides. I bought the IR temp tool recently because I thought it would be handy to have, and it was.
- Checking in with the forum that my assessment that a bad outer bearing is correct
- Also to note I have .026" end play and the book is .006 (I'll fix this when doing the bearings)
- U-Joints are cool as a cucumber and no evidence of spinning bearing caps.
Thanks for help & advice,
Jim
Jim
