I am installing a Delco distributor with the Pertronix module into the 62 Champ & wanted to use the (red) feed wire that normally goes to the overdrive switch on the throttle linkage. On testing it though I found there is current to that wire when the ignition switch is in the "ACC" (accessory) position. I cannot see in the wiring diagram where the source is, could a different wire on the ignition switch be moved so this wire only gets current when the ignition is in the "run" position?
As a side note in speaking with one of the advisors at Pertronix a couple of things came up. First, if using one of their coils a full 12 volt feed is recommended. Second, the distributor "lead wire" that grounds the breaker plate to the body must be intact. I had to replace it on mine before I put it in. It was broken off at the breaker plate. I replaced it with an Echlin LW 42 from NAPA. One word about this wire, it has a closed end connector on each end & one end the hole is too small for the screw that normally holds the points. Based on illustrations from different sources this is the way they come such as the BWD DL 77 & the Standard Motor Products DDL 21. I thought I would mention this because of various posts telling how the Pertronix units failed for them. The break in this wire may or may not have been the reason.
