....been a while .... what are the precautions when jump starting a generator charged system and an alternator system ?
Jump Starting : Alternator and Generator
Tags: None
Shouldn't make much difference, gen or alt. As long as voltage is the same.
From the live vehicle to the dead vehicle, battery positive to battery positive; battery negative to dead vehicle ground. You can go battery negative to battery negative but, there is less chance of spark and explosion if your dead lead is to a chassis ground. Just saying from experience.
If you are jumping a 6-volt system from a 12-volt system, hook up your grounds from battery to battery. Hook your positive to 12-volt battery positive; have someone in the car hit the starter while you lightly touch the positive cable to your 6-volt battery positive. Short 12-volt bursts to the 6-volt starter are invigorating but longer bursts can easily fry your ammeter.
The nice thing about a generated system vs. an alternated system is, once you are running, assuming your generator and voltage regulator are working correctly, you do not need a battery to keep you safely on your journey. Without a good battery, an alternator system cannot function."All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
Just out of curiosity, how would one boost a positive ground vehicle with cables connected to a negative ground vehicle. Still positive to positive and negative to negative? That seems obvious if using a battery that is not in a car for the boost. But I would be leery to try this if using a running 12 volt negative ground vehicle to boost a positive ground 6 volt vehicle. Who knows what would happen to the 12 volt vehicle given today's computerized systems.
Regarding boosting from one car to another when both are the same voltage and both are negative ground, it is better not to run the negative cable ends to the negative battery terminals. Instead, connect the cable ends to bare grounded metal on the engine block or nearby. This lessens the possibility of explosion, so they say. I expect the same recommendation would apply to vehicles with positive ground - that one would connect the positive cable ends to a grounded spot in the engine compartment. Also, always connect the ground cable last.
Years ago, I got a friend's car started with a length of heavy solder. We touched the front bumpers of the cars together and then used the solder between the positive posts of both batteries. The solder got hot, but the car started. Since then, I've used that trick twice, once even using a folding jack handle to connect the positive posts. Wouldn't try it on a modern car for two reasons: non-grounded plastic bumpers, finicky ECM.
I did have a 6v battery case blow up when I boosted with a 12v, but I have done it many times before and after. Just stand back in case it does happen!
Remember that 6v cars were typically positive ground, while 12v were negative ground.
Originally posted by northern View PostJust out of curiosity, how would one boost a positive ground vehicle with cables connected to a negative ground vehicle. Still positive to positive and negative to negative? That seems obvious if using a battery that is not in a car for the boost. But I would be leery to try this if using a running 12 volt negative ground vehicle to boost a positive ground 6 volt vehicle. Who knows what would happen to the 12 volt vehicle given today's computerized systems.Skip Lackie
Originally posted by jackb View Post.....for some reason, as in jumping a '62 and '63 GT Hawk(s) many years ago (1973)..... I thought you could only "jump" one way.....I thought you could damage one of the units if jumped wrongly.....??
I think this old "Worry/Concern" comes from MIS-remembering the warning that all early Alternator Equipped vehicles had similar to this Decal:
"WARNING, CONNECT POSITIVE TO POSITIVE and NEGATIVE TO NEGATIVE"
Really that is all you need to do, if you do not, DAMAGE will occur.StudeRich
I have always connected my jumper cables doing the ground to the engine block itself last, away from the battery & any chance of sparks or explosion. It also does away with the chance that the ground wire from the battery isn't up to par.59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
Although it creates alternating current I believe it becomes direct current when it passes the diodes so there is no difference & it is all direct current regardless of it being a generator or alternator. No vehicle made that I have ever seen runs on AC, all are DC.59 Lark wagon, now V-8, H.D. auto!
64 Zip Van
66 Cruiser V-8 auto
