Hi there Gang. Work on changing out the 4.89 in my 2R5 to a TT 3.73 is progressing well. Slow, but well. I finally got all my shims and adjustments made and put the carrier into the case. Due to the .008" extra shim to provide bearing preload, that increased my backlash from .0035 to .010. I'll need to bring that down below .006". Not a major concern, but i made a tooth pattern while I was in there. The pinion rides pretty high on the ring teeth, top half of the ring teeth show clean from the prussian blue. SO, i need to get the pinion out closer to the carrier to get the pinion tooth contact a little deeper on the ring teeth. Here is my question to all you BTDT's on the list...
Is there a relationship between how much shim i remove from the pinion bearing cup to how much the tooth contact area changes on the ring? i.e. add .003" shim to the pinion and the contact area will move 1/16" deeper on the ring... Is there such a relationship? I'll do it if i have to... but i'm not looking forward to pushing out the pinion .003", completely reassembling the entire rear end just to get a wear pattern, to find out i need to do more. I imagine I could come up with a mathematical relationship from the first adjustment, and calculate the new shims the second time around, but since the tooth isn't flat (the contact surface is beveled) the relationship wouldn't be linear, and one measurement wouldn't be enough. Just looking for a little time saver... thanks all in advance for your help, experience, and wisdom!
My dad told me years ago good judgement comes from experience. Experience comes from bad judgement...
chris
chris
