Back in the 1990's, I ordered two disc brake conversion kits from Dave at Steeltech. One was his deluxe kit that included his adapter brackets, calipers, and pads. The other set was just the adapters. He sent no instructions with the kits. I called him and he told me what what rotors to buy, so I went to most wrecking yards in my area, and purchased the rotors Dave specified. Unfortunately, each and every rotor was worn way too thin, and no machine shop would turn them. So, I returned them all to the wrecking yards. I asked Dave more than once for parts needed lists and instructions, but never received such. Disappointingly, I boxed the stuff up and put it back on the shelf until a few days ago.
It is now time for me to revisit such projects, as I have a couple cars I'd like to convert to discs. I had two phone numbers for Dave, but now neither re working. Thus, I would like to inquire of my fellow forumites if anyone knows the answers to the questions that follow.
1) I do not remember what rotors I bought some 20 years ago. 'Seems to me they were something like Chrysler Cordoba from the early 70's, but I would not bet my life on it. Does anyone know for sure what rotors I am supposed to buy?
2) If I buy Chinese rotors am I likely to have a problem?
3) What do I use for inner and outer wheel bearings, races, and grease seals?
4) What do I use for brake flex hoses?
5) Dave said that his kits were designed to be so big, powerful, and effective that I would not need power assist. One of my intended applications is a fully loaded, 2 ton, '64 Daytona wagon. Can I indeed get by without power assist?
6) Once installed, do Dave's brakes work well, or are people having problems?
7) One bracket/caliper assembly has a bit of red spray paint on it, and the other assembly has a bit of blue. I presume this was to designate left from right. Does anyone know which is which?
8) If I am successful in using the deluxe kit, I will need calipers for my "brackets only" kit to do another car. Can anyone identify these calipers so I can know what to order in the future?
9) Is there any other info I should be aware of?
Along with the kits he sent , there was an empty brake pad box Carquest BD85. I presume these were the pads installed on the deluxe kits. Maybe this will help someone identify what I have. Attached are a few pictures I took of both the deluxe assemblies and the brackets only. I sincerely thank you in advance for any help and guidance provided.
Larry
Larry
