In the past, I have only lubricated rubber brake components and other components within wheel cylinders with brake fluid.
Question: Can anything be used in new wheel cylinders to stop seizing besides using silicone brake fluid?
(1) Sil-Glide, Antiseize, Copper Antiseize and other greases cannot contact the brake fluid or other internal rubber parts - corrrect?
(2) It is OK to use Sil-Glide, Antiseize, Copper Antiseize and other greases for metal to metal contact in brakes, such as the metal pistons within the cylinders, the adjusters, the top at the of the brake shoes?
(3) Only use brake fluid to lubricate rubber parts?
(4) Use small amount of liquid dishwashing detergent on internal wheel cylinder rubbers to stop seizing?
(5) If everything is new on a brake system except the power booster, can you use silicone or must the booster be flushed with alcohol? Procedure?
