Well, this is not a studebaker starter, but its a 6V starter non the less so probably the same enough that the topic has value here.
Can you expect to be able to spin the starter using a battery charger for power? Starter sitting on the bench, armature will turn by hand. Starters being series field I know they take a pretty huge current at low speed. But, w/o any load should it at least turn some?
I've never tried to bench test a starter before so not sure how much no-load current is needed. My attempt just pegged the ammeter on the charger and the shaft didn't so much as twitch. If I had some jumper cables on hand I would have used a half dead 12v battery instead.
The reason for looking at this was I pulled this out of a tractor that would turn over SO SLOOOOOOOW that I found hand cranking it to be faster. Really. Often the bendix wouldnt even spin out on the nose it was so slow. Wiring on the tractor is poor and the starter switch (direct acting, no solenoid) could be shot but since I don't think the starter has been checked out for at least 40yrs (more like 50+) it was worth looking at it. I got it apart and the brushes seemed OK for wear, bushings OK (not egged out), and armature not dragging on the fields. Unless there is a bad winding, Its probably fine. I cleaned up the commutator with some fine sandpaper, scraped out the carbon buildup out between the segments and put some fresh grease on the bushings and put it back together. But, Id still like to verify it will spin.
