What color wires go to which terminals? My ignition switch was removed when I bought the car and I don't know which wires go to each terminal at the rear of the switch. Thanks! Harvey
Avanti ign switch wiring help
Tags: None
White with red tracer goes to the start terminal (center) that wire goes to the neutral safty switch, then to the starter solenoid.
White with black tracer, goes to ACC terminal and that goes to the fuse block. If you have AC, there should also be power to that comming from the ACC terminal of the ign switch.
The IGN terminal will have two wires, yellow, with a black tracer that goes to the ign terminal of the voltage regulator,, and a black with a pale green stripe that goes to one side of the ballast resistor, (which then goes to the + terminal of the coil).
The last connection, is the Batt. (+) terminal if the ignition switch, and it gets a heavy black wire, that goes to the Ammeter.
Good luck, don't let any smoke out of the wires.Bez Auto Alchemy
