Please explain why the wires on the fuel and temp would not need to be reversed also.
Another 6v to 12v conversion
A good reason not to use dropping resistors unless you absolutely have to is the 6volt equipment draws twice as much current as a 12 volt unit does. Depending on which radio you have, the 54 radios draw between 7 and 10 amps. If converted to 12 volts, properly, they draw 4 to 5 amps. The extra current becomes heat and the 6 volt units still draw the same amount of current, harder on the battery.
MPallock has completed the wiring modification to his car using the same system I described.
He used a battery from Antiqueautobattery.com that does essentially the same thing as two 6 volt batteries in series.
If you want to find out how to do it Antiqueautobattery.com has info on how to wire the system.South Lompoc Studebaker
