This transmission Dick shows in this post (number 14) is definitely a GM input shaft and in my opinion the ring(s) on GM inputs have no relation to the Stude inputs. The trans Dick shows in post number 9 is definitely a Stude input shaft so I'm still of the opinion the Stude inputs with the ring is a 2.54 and no ring a 2.20.
To tell for sure what you have, if the transmission is out of the car, the easiest way is to put it in low, rotate the input one turn and note the turns of the output. If it turns about 2 1/4 turns it would be a close ration and if it turns about 2 1/2 turns it would be the wide ratio.
If you want to pull the side cover off and count the teeth, here are the teeth counts on the two ratios: The wide ratio is:
Input shaft is 25; third 29; second 30; first 36
Cluster front is 30; third 23; second 19; first 17
Close ratio is:
Input 27; third 29; second 32; first 36
Cluster 28; third 23; second 20; first 17
You can see to change from one ratio to the other, you only need to change the input, second gear and cluster gear.
If the transmission is in the car, follow Dick's instructions in post number 9.
Hope this helps rather than confuses.
Ted
Close ratio is:
Ted
Originally posted by Dick Steinkamp
View Post
