Hi All - I've discovered some pretty severe rust (see pictures at)
http://s170.photobucket.com/albums/u278/My60Hawk
I'm pretty much an amateur at this stuff so I'd appreciate any and all help.
Most of the rust seems to be concentrated in the joint between the kick panel and the floor. At some point in time, someone put in some floor patches using galvanized sheet metal and screws then undercoated the underside. I haven't removed the fenders so I don't know what's behind the kick panels. I also don't know how to judge the severity of the problem although I understand that the front pillar supports a lot of weight.
I see that Classic Enterprises has new floor panels and pillar base supports that can be put in. They also have an inner fender kit that is supposed to, at least, help eliminate some of the problems in these areas.
It does not seem that there is a problem with the rocker panels. There are no paint bubbles or other indications there. The rear floor panels all seem quite solid as does the trunk.
I know it's asking a lot but if someone could give me some insight on how far I need to go to repair the problem, I'd appreciate it greatly. If more pictures are needed I can do!
Thanks,
Mr Mike
Thanks,
Mr Mike
