I finally have Lucy to a point where she's ready for her first drive. The best I can tell she hasn't been on the road in over 10 yrs. I've not done anything to the FOM other than change the fluid/filter, which was still red and no particles in the oil. Is there anything else I need to do before I take her on her first drive (other than cross my fingers and hope I put everything back together properly?
Transmission question.
Anything sitting for 10-20 years needs all the fluids and lubricants replaced. Drain the coolant and reverse-flush the system, engine oil, (you've already done the tranny) differential lube, brake fluid, PS fluid, . Do a complete lube and oil change by the book, all new belts and hoses.
FWIW, I always do the first drive on jackstands. While you are bleeding the brakes, run the engine it til warm. Then, go up and down through the gears, forward and reverse, stopping using the brakes. There is usually always something better to discover in the garage than in the middle of a busy intersection ten miles from home.
thnx, jv.
PackardV8PackardV8
Brakes! A complete and thorough inspection and/or rebuild. Did I remember to suggest brakes? Also, don't neglect the brakes!
Brad Johnson
'33 Rockne 10, '51 Commander Starlight, '53 Commander StarlightBrad Johnson,
'56 Sky Hawk in process
I would say you're good to go! If you don't know when the trans and rear were last serviced, a flush and fill can't hurt. Then again, this comes from someone who never has flushed the rear in the Rockne I bought fifteen years ago.[:0]
Brad Johnson
