Thought I would eliminate the last oil leak in the '60 Lark convertible coming from rear of engine. Likely culprit was the oil pan gasket. After reading tech advice and shop manual I blocked up vehicle removed starter and oil level tube. Began looking at bell crank assembly, seems very difficult to remove. Removing exhaust appears to be necessary. Not sure how to get at all the pan bolts. Seems like its a job done more easily with engine out. Can it be done without removing bell crank? At the moment, I'm tempted to leave it alone and live with a leak. Any advice?
Oil pan gasket
Lark V-8 Oil Pan removal
Yes you need to remove the exhaust head pipes from the Manifold (if you have single exhaust, may be a good time to switch to DUALS!) and drop the center Steering pivot, then you can swing the tie rods out of the way and bailing wire them to the frame. This is not as hard as it may seem.
Just be sure you remove the Zerk fitting in the Steering Center support FIRST, then remove the Clamp to Bellcrank on top, then the four bolts & nuts that secure it, and that part is done.
I always hate messing with rusty old exhaust pipes, but maybe your's are not the worst, just have 3 New Flange Gaskets, thick type for a '61 Ford Falcon 170 6 Cyl. or the Stude. Vendor Flange kit, because you will also need 4 Brass NF 3/8" Nuts and hopefully NOT the 2 long & 2 short 3/8" Manifold STUDS also in the Kit.StudeRich
A tap and die set is real handy to have around when dealing with manifolds. I like to run a die up on the exposed stud threads before even trying to take the brass nuts off.
nate--
What I did on my 63 Lark when the rear u shaped end cork gasket was leaking was to take off the starter and the flat bell housing plate for access. I then cleaned the surface of the cork end seal with brake clean and applied (black) silicone sealer to it with a tool like a flat screw driver or spatula. No more leaks. Sure saved me from pulling the pan off. Might try that first because the end cork gasket is usually the culprit!Last edited by 41 Frank; 02-26-2011, 07:26 AM.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
If using RTV for"external sealing" don't use white tub sealer like I did. It worked fine for a long, long, time, but was a highly visible reminder to me and brought instant attention to the "shameful" thing I'd done, even reflecting badly on my parents.. The Blue and Red RTVs HIGH VISIBILITY make it obvious if they are not used sparingly. Often when looking at a used car or bike a "just rebuilt/replaced something or other" is proudly played as a positive selling point. If there is Red or blue ooze along a bolted joint I cant help but consider the repair and even the entire vehicle as questionable, and not just because there is likely an evil twin rubber snake on the inside, waiting to break free and create mayhem.
Thanks StudeRich, I'll revisit the bell crank removal after your note 'cause it sure seemed tough to get at to me. Thanks for the exhaust advice. I have to do it anyway because I discovered one of the exhaust manifolds had a crack.Thanks also Nate. I'll try the 'die' trick. I hadn't thought of an external solution Frank, but I'll certainly look at it. Need to look for that bell housing plate and be careful with silicone application as Dan suggested.sigpicJohn Esmonde
Holland Landing, Ontario
Canada
\'62 Hawk
\'60 Lark Regal Convertible
\'30 Chev Coach
I forgot to say I also did the front gasket that way and it also stopped any leaching out of oil through and around the cork just like yours. It is also a good idea to check the distributor gasket as any leak there will run down the bellhousing and mimic a leaking pan gasket.
Originally posted by FlatheadGeo View PostI used the same method that 41Frank did but on the front under the crank pulley. It works!Frank van Doorn
Omaha, Ne.
Little milder in Ontario today. Fired up garage furnace and got at cleaning the rear of the oil pan and removed the bell housing inspection plate. It seems to me that the bearing cap seal is not leaking so it must be the cork piece at the top. Got things cleaned fairly well, will do it again and then try applying sealant to the exterior of the cork gasket. Hope it works. Ordered new exhaust manifold and gaskets from SI this morning . In all a good Studebaker day following help and advice from the forum. Thanks.sigpicJohn Esmonde
Canada
\'62 Hawk
\'30 Chev Coach
John- I just replaced the oil pan gasket on my '51 Champion. You will need a "pickle fork" to get the tie rods off of the bell crank. I got one at Harbor Freight cheap. But the best advice I was given by someone in the group (sorry, don't remember who) was when your ready to reinstall the pan, Have 6 threaded studs screwed into the corners and center of the block where the oil pan bolts go. this aligns the pan and keeps you from contacting the gasket dressing while your putting the pan where it belongs.
Try any of the "Ultra" sealers from permatex. They seem to hold up well. I have been putting a coat of the ultra gray sealer on the two end corks when I put an engine together. So far so good.Jamie McLeod
Hope Mills, NC
1963 Lark "Ugly Betty"
1958 Commander "Christine"
1964 Wagonaire "Louise"
1955 Commander Sedan
1964 Champ
1960 Lark
Tie Rod End Removal
Originally posted by JohnMSeymour View PostJohn- I just replaced the oil pan gasket on my '51 Champion. You will need a "pickle fork" to get the tie rods off of the bell crank. I got one at Harbor Freight cheap.
But here is another tip: the Pickle Fork is not needed if you know this trick.
Back-up one side of the Reach Arm or Bellcrank that the tie rod end goes through, keeping pressure on it with a heavy Hammer, then bash it 180 degrees away, on the opposite side with another Med. to heavy Hammer with the Cotter Pin and Nut removed, it will fall off!StudeRich
