For a '53 Coupe--does ALL vent rubber fit this badly, or was I sent the wrong item? The top, as fitted in the correct spot, is fine; the bottom is off by over 1 1/2". The hole for the vent pivot is off by about 3/4".
Vent rubber
Is it possible that you stretched it while installing it? The frame needs to be very slippery and the rubber compressed into the frame. Set the ends in place and the pivot hole in the correct position and then squeeze the remaining rubber into the frame. A coating of WD40 on the frame and rubber will make the job go easier.
I just finished installing SI vent rubber on my 53. Looked way too big when I started but was able to compress the rubber to fit correctly. Installing the rivets was a two man job. Using soapy water worked better than WD40 because the WD40 attacked the rubber leaving black smears everywhere and the soapy water did not. Of course, I'm secretly hoping we never have to open the vent wings once they're sealed!
Regards,
John BraytonJohn Brayton
Originally posted by WCP View PostIs it possible that you stretched it while installing it? The frame needs to be very slippery and the rubber compressed into the frame. Set the ends in place and the pivot hole in the correct position and then squeeze the remaining rubber into the frame. A coating of WD40 on the frame and rubber will make the job go easier.'53 Commander
Art Morrison chassis
LS6 ASA/4L60E
I got seals for my '53 C from SI a few years ago and they went in with no issues at all. Has to be the wrong item.Brad Johnson,
'56 Sky Hawk in process
I installed a pair in the vent windows of both a 51 sedan and a 53 hardtop. Most are a challenge and require patience. I've decided that new reproduction pieces are molded from NOS. Just an opinion, but I think that makes them just a bit bigger, or fatter than original. Again, that's an opinion. Both cars required closing the vents by compressing them from the outside and then pulling down the handle to lock in place. On one car, it took a bit of effort and the rubber bulged a bit when close.
Kim
Humble opinion....unless you "have" to replace the rubber on your car or truck....don't do it. Especially if a trailer queen...There are plenty of treatments out there that will spark up the appearance of the old rubber.....who's looking for it anyway ? Does NORS "score" better than original ?
