I'm rebuilding a '64 259 V-8 that has 1557570 cylinder head castings. I've read several posts on the forum regarding chamber volume and I expected these to be around 54-55cc's. I cc'd all 8 chambers and got between 59.6 - 60.8 cc's. These numbers seem high to me and I want to see if anyone has measured 570 heads and found chambers this big. I'm using a 100 ml graduated burette with a 1/4" thick clear plastic plate. I seal the plate to the head with thin grease. I'm not detecting any leakage past the valves or spark plug. The valves and seats have been cut and the springs had to be shimmed 0.015" so some of the volume may be from valve recession. I will probably have the heads cut to make up part of the volume but I want to make sure the numbers I'm measuring seem reasonable. I haven't reshaped the combustion chamber, only deburred the edges. Any suggestions on how much to cut the deck are appreciated.
Neil
Neil
