Linkage needed.
  • Linkage needed.
    I am in need of the linkage that goes from the steering column to the Automatic transmission, the inserts/bushings are needed as well. Ive tried a couple of places and no one seems to save this stuff.[B)] You can contact me off forum. Thanks![8D]
    Edit: Sorry I knew it was an Automatic I figured everyone else knew as well...[:I]
    Randy_G
    1959 Lark Sedan
    www.AutomotiveHistoryOnline.com
    I have a 62 Lark parts car with automatic don't know if the bushings are there. Don't know if this info helps. Let me know.
    Mabel 1949 Champion
    1957 Silverhawk
    1955 Champion 4Dr.Regal
    Gus 1958 Transtar
    Fresno,Ca
    Mabel 1949 Champion
    Hawk 1957 Silverhawk
    Gus 1958 Transtar
    The Prez 1955 President State
    Blu 1957 Golden Hawk
    Fresno,Ca
      Don't know if your transmissionis automatic or not, but if automatic and you can't find the parts you need, you may want to try www.lokar.com they are a Hot Rod parts mfg. but they carry an automatic cable shift linkage. I am converting my Chamnp Pickup to a 700R4 transmission and their linkage seems to work perfectly. Don't know if this helps, but...
      Laisez le bon temps roulez avec un Studebaker
        A shift rod (link) from a 59-60-81 Lark type (W/auto trans) will fit - V8 & 6 used the same. Part# 1547593 '62-3-4 carry a different part number.
        There's NO bushing at the upper end - only a washer and a cotter pin. At the lower end, there's a swivel part #1541533
        Miscreant adrift in
        the BerStuda Triangle
          Anne, I e-mailed you about your linkage and I wanted to thank everyone for there quick response. Hopefully I will find some much needed parts this weekend at the Pate swap meet.
          Randy_G
          1959 Lark Sedan
