I pulled my engine today and started tearing it down. I already knew I had starter problems because it didn't always engage, it would sometimes make that aweful gear grinding sound that makes you shiver.
Once I got the bell housing off, I discovered 4 areas on the ring gear with obvious damage to the teeth where the starter drive gear had been grinding. The starter drive was also in pretty bad shape.
I know you can replace a starter bendix and I saw where SI sells a new ring gear. The service manual says the ring gear is shrunk on the flywheel but I couldn't find any info on replacing it. Shrunk on tells me the ring gear would have to be heated to be installed.
I need advice on installing a new ring gear. All advice appreciated.
Thanks
Thanks
