Edelbrock 600 Carb to Stude linkage/bell-crank
  • Edelbrock 600 Carb to Stude linkage/bell-crank
    Recently installed Edelbrock 600 on Offenhauser intake on 289 with .elec. fuel pump.What would be the correct hole to use on the carb?The slightly small perfectly positioned one or the large one (slightly forward)where you have to make a bushing?I've been using the small perfectly positioned hole but my kick-down won't work.
    Last edited by Stu Duglee; 09-18-2010, 11:27 PM. Reason: shuold have put more info
    The large hole. I got new linkage from JEGS that came with bushings, but prior to that, I just used washers.
    Joe D.
      Either one will work. I used the small hole, and adjusted the linkage to the trans per shop manual. That was over 120k miles ago.
      Gordon
        Either hole will work on a 4-speed, but on a Flightomatic or Powershift you need to use the big hole. I suspect the same is true if you have a 3/OD as well, so that the kickdown works right at full throttle. The center of the big hole is just about the same distance from the primary shaft as the hole on the factory 4-bbl linkage.
          As noted...either...!
          Just a little ratio difference is all the difference.
          I used the small hole with the same setup as you have. This way...no extra junk is required, just adjust and go.
          Your kickdown adjustments are a seperate deal. You need the "right or correct" ratio there. The linkage plate must have a connection at the right location for the correct ratio.
            huh?
            Joe D.
              I use the small hole on my R-1 with 4speed
                The large hole keeps the same throttle throw. I used a piece of fuel line with washers on either side for a bushing. Takes up all the slack and operates smoothly.
                Jim
                ____1966 Avanti II RQA 0088_______________1963 Avanti R2 63R3152____________
                  Where did you get your new linkage...JEGS?Do you have an address ? I need a 4BBL linkage rod as the 2BBL one isn't long enough
                    JEGS part# 555-15795 (Universal Throttle linkage); phone number is 800-345-4545.
                    Joe D.
                      On my '62 I just used a piece of all-thread and some Heim joints, but if you have an automatic you might want to keep the stock spring-loaded deal. You could use half of a universal kit if it had the same thread.
                        Thanks valleyguy & everyone else
