62'-63' GT Hawk Deck Lid Overlay
  • 62'-63' GT Hawk Deck Lid Overlay
    Has anyone come up with a suitable way to attach the overlay when the majority of the
    mounting screw retainer tabs have been broken off??? Obviously drilling holes and using
    #10 sheet metal screws is not an option and neither is "double-sided emblem tape". And
    OBTW, JB Weld, as well as other similar products won't keep the original mounting screws
    from popping off. Even after sand blasting the small area for a rough surface to glue to.
    Any other suggestions would be greatly appreciated.
    Dan Miller
    Auburn, GA
    Fusor metal bonding adhesive can be found at good paint stores. Use anti seize on the studs so it does not happen again. Fusor can only be removed by heat at about 400' so be sure you get it in the right place.
      I used the two sided tape on my '62 and have had no problem, 4 years and counting.
        Thanks (S), I checked some major hardware stores with no luck, but on line it appears it would be easier to find at an auto body shop supply outlet. I'm working on it.
        Thanks Pat. My problem with the double-sided tape is should you have to remove the overlay, it will look like a pretzel by the time you get it off. I had a parts car one time someone had stuck that overlay on...what a mess. Not only that but the tape will not hold it tight around the edges and leaves and straw find their way down behind the overlay. Just my observations. Thanks
        Dan Miller
        Auburn, GA
          Looking for a product that can effectively patch dissimilar metals on vehicle panels? You should try the Lord Fusor Metal Bonding Adhesive (Fast), which will be an asset to your body shop. It is one of the best products for panel bonding and bonding of different metals, cab corners, different panel sections, and even aluminum trailer patches. To Use the Lord Fusor Metal Bonding Adhesive (Fast): Remove any rust or damaged area on the panel Cut a patch panel to fit the area to be repaired while leaving at least ® inch (19 mm) overlap for best results Grind the surface to the area which requires the application of the bonding adhesive to not greater than 1 inch (25.4 mm) Insert the Lord Fusor adhesive cartridge to an applicator gun Squeeze some adhesive from each side of the cartridge to level the plungers and make sure that the adhesive comes out from both sides of the cartridge Allow the bonding adhesive to cure for at least 30 minutes before unclamping the panel Remove any excessive adhesive for a clean finish Features of the Lord Fusor Metal Bonding Adhesive (Fast): The versatile product is suitable for the installation and bonding of bare metals including aluminum The bonding work does not need welding It provides guaranteed protection from corrosion Cures fast Work time is 5-8 minutes at 70°F (21°C) when mechanically fastened or 15-20 minutes at 70°F (21°C) Full cure takes 2 hours at 70°F (21°C) Offered in two sizes: Fusor 110B = 7.1 oz (210 mL) and Fusor 111B = 1.7 oz (50 mL) OEM Approvals Include: GM: Panel replacement per TSB 02-08-98-001A, meets GM6449G DCX: Weld bonding per 81-170-03005 Nissan: NTB96-034A This item can only ship by ground within the ContinentalUS. Next Day or 2nd Day, AK & HI, & International delivery not available. WARNING: This product can expose you to Aniline which is known to the State of California to cause Cancer. For more information go to www.P65Warnings.ca.gov.
            I've heard a lot of great things about the Fusor, and intend to use it in a few places on my '59. From what I've been told, if you ever want to remove that overlay, Fusor is not the way to go.
            FWIW, it'd seem that double-sided-tape would hold the edges down, if you put the tape on the edges.
              Matthew,
              Just to be clear, I would be gluing the original mounting screws to the overlay, not gluing the overlay to the deck lid. This way it will mount the way the factory
              intended and seal all the way around. The thickness of the tape will allow leaves straw etc. to get down behind the overlay, then hear comes the rust.
              Dan Miller
              Auburn, GA
                How about adhesive backed magnets? Stick the thin flexible magnets to the aluminum overlay and let the magnetism hold the overlay to the steel trunklid. Should be strong enough to hold it on, yet weak enough to remove it with little force. Don't like that idea? How about some clear silicone sealant? A few beads applied with a caulking gun should hold it on, yet not the strongest bonding agent available. A bead around the inside perimeter edge will also keep dirt from getting in there. Perhaps a latex based sealant would be better?
                In the middle of MinneSTUDEa.
                  I'm thinking, just stick the overlay on with the double sided tape directly to the trunk lid - but do it "sloppy" so the tape actually sticks out outside the edge of the overlay. then trim it with a razor blade after it's installed. leave a little gap in the middle of the bottom of the overlay so that if anything *does* get behind there it can drain out.
                  NB: I haven't tried this, I'm just thinking out loud.
                  Some of the double sided tape is pretty strong; some of the 3M stuff has been holding an auxiliary gauge panel under the dash of my pickemup truck for several years now.
