How come when a core plug decides to leak, it's always the one above the starter???? I mean there are five others that could have been a little easier to get at!!!!
wouldn't ya know it!
Doesnt really matter. If one goes you should replace them all. And while you are in there flush everything. Going through the same thing on the T-cab now (center right side one popped). New plugs arrived today!! Stevesigpic
I think the rear ones tend to go first for some reason, not sure why. They're the ones you should knock out anyway to clean out the block; you might as well pull the starter and flush some water through it while you're at it.
nate--
rear ones tend to go first, because there is more "crud" back there!
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
Indy Honor Flight
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
There is a pipe plug type thingy on the same boss area as the rearmost freeze plug on the right side of my engine. Is it a drain for the block that should also come out for cleaning or something else (like maybe an access to the oil galley for a mechanical guage)? My block wasnt too bad as someone has replaced several freeze plugs over the years and presumably cleaned everything while they were there. Thanks, Stevesigpic
pipe plug
The pipe plug is a drain for the block anti-freeze. I put a petcock on mine to facilitate flushing the cooling system.
My engine was totally gone through not that long ago and was completely cleaned. I think(it looks like) that the core plug isn't in far enough.....it's not flush like the others.
I shoulda, woulda,coulda done them my self, but was part of the machine shop services.Bez Auto Alchemy
Originally posted by bezhawk View PostThe pipe plug is a drain for the block anti-freeze. I put a petcock on mine to facilitate flushing the cooling system.
Thanks for the info. Make sure the machine shop used the correct plugs. Mine has 3 different metal ones and a rubber one in it. I think the one that gave up had been replaced with one that was too small. The one opposite it was slightly smaller in diameter and otherwise the truck had a mixture of shallow and deep plugs in the other holes. It was a farm truck before I bought it and I guess they used what was onhand when they replaced them. My local FLAPS had a mixture of the deeper ones and the rubber ones but not enough of either and no brass so I ordered all 6 in brass from SI. Dont remember exactly how much they were (I ordered other stuff also) but not a budget breaker. I got all of the old ones out today and got everything pretty well rinsed out between rainstorms. Hopefully I will be able to get them back in tommorrow morning. Good Luck with yours, Stevesigpic
