tach wire setup
  • tach wire setup
    55 stude speedster, can anyone provide a wiring diagram for the tach cable in my speedster. ther are three wires pulled out of bothe ends of the cable that goes thru the dash connecting the tach to the sending unit, the wires are not color coded or at least I can't see any color to them. there are 2 prongs clost togeather and one alone.
    Thanks in advance
    Forrest
    http://www.ncsdc.com/TechnicalPages/Tachometer.htm
    64 GT Hawk
    64 R2 4 speed Challenger
    63 R2 4 speed GT Hawk
    53 Street rod
    JDP Maryland
      also try
      http://home.comcast.net/~njnagel/tach.html
      HTH
      62 Daytona hardtop
        I am also trying to restore the use of my original tachometer in my Speedster. I have assembled all of the pieces to make it all work - EXCEPT the two little clips that hold the dist. cap and sender to the distributor. I have learned that these little spring steel clips attach to the spring clips on the distributor as 'extensions' and these hold the entire assembly to the distributor. Does anyone have some of these clips or know where I might find them?
        Jim W.
        James D. Wilkerson
          Does anyone know if it is safe or possible to 'bench test' these tachometers? I'd like to test it before I it all back together. Can I apply 6V or perhaps less to test the tach unit?
          Thanks.
          James D. Wilkerson
